- 20 Feb 2009
- Ashton-Under-Lyne
Ok, so I've been wondering this, is there much difference in the audio quality between the optical output from a motherboard, and the analogue output from a decent dedicated sound card?
Theoretically the optical output's quality should depend completely upon the quality of the decoder in the amp, however if this was the case, surely the amp will be pretty much the same quality whether it's an optical, or analogue input to it, and as such, a dedicated sound card would either provide worse quality sound, or the same (as the amp would degrade the quality anyway)
I know none of it works quite as theory says it should, however I don't know how close/far from this it is, or what you need to spend on a sound card in order to get better quality (is it £10, or is it £200?)
If I decide to buy a dedicated card, it will only be a reasonably cheap on (probably £30 or so max), so would I be better off just using the optical out from my motherboard (Asus P8P67 Pro B3 (when it arrives from being replaced
)), or should I buy a dedicated card (in which case which?) and use the analogue outputs from that (or even the optical output?)
I hope some of that makes sense to someone, and they can help me with it, it made sense to me whilst I was writing it
