I have never had the knack of skimming the stones perfectly on water, people say flat surface stones are best, I can usually get two skims and have got about four.
The more flick the better, I find. Smoother rounder and flatter pebbles are best, but really you can get pretty much any shaped stone to do a couple of bounces with the right technique.
Angle is very important... you want to release it so it's angled slightly upwards, but not too much.. I'd say about 30 degrees max... any more and it'll do the next bounce or two more to the vertical and just bomb
Don't throw it as hard as you can. You'll probably fail.
The stone must become your arm; the water your mind. Breathe deeply and attune yourself to that vast cosmic wateryness. Let the stone fly, free and graceful like a... skimming thing.
With skill you can skim just about anything - I saw someone skim a stone about the size and shape of half a brick once!
I usually only get about 3 or 4 bounces, but like most things, practice really does help... getting the angle and spin right, getting a smooth release, and not putting excessive effort in seem to be important to me.
