**Official Portal 2 Spoiler Thread** - SPOILERS AHOOY
I loved the fact that Chell's BYDTWD potato grew out of control and was huge when you got to it! :D
Anyone think that Chell may have been simple/brain damaged from the start? That would tie in with her having a project in BYDTWD and being 20ish?
Also it could be that Caroline didn't want Cave's daughter to be seen as weak, so helped her with the uber potato?
I know I'm assumign a lot but it could work! ;)
Has anyone played with the developer commentary?
Was all very interesting, but when I got to the final battle there is a node at the stalemate resolution terminal but as soon as you enter that area the bombs go off and you are locked in to the final part of the game with no ability to go back to it?!
That's because you aren't meant to go back to the button. I'll give you a hint - the portal gun appears to have indefinite range.
I didn't see the last dev commentary node until i was already getting blown backwards across the room so i'm gonna have to do it again from chapter 9 to find out what it says...
But there is a section where you have to bounce through 2 portals holding a 'Discourage redirection cube' into a laser beam so you can fry some turrets.
Absolutely awesome :D
Does anyone know about the director commentary bubble in a secret room with all the coffee mugs? It sounds like a program you can load from a tape deck like a commodore 64.
http://steamcommunity.com/profiles/76561197969394979/screenshot/595809294209956270?tab=public
This video shows how to get to the room
To get there quickly open the console and put in these commands:
sv_cheats 1
commentary 1
map sp_a2_pull_the_rug
*Then when the map is loaded*
noclip
Edit-
Someone posted it on youtube it seems so this is a faster way to get to it :D
I hope there is an extended version of the turret opera in the pipeline. It was just perfect after the "Oh **** no!" of the 4 turret firing squad opening.
I'm really hoping for this as well! i really like that song i would love for a longer version. It really was a great moment when the turrets started singing :D
Only thing i didn't like about the ending (and this is me being a fussy tit), it that it was a video file not actually the source engine doing the show. Would have loved to noclip my way around the room just to watch the mechanics of the scene. :(
Found one whole genuine winge so far, when weatley is in the ceiling of your room, as the room falls apart you can see there is an untextured black box covering the space that he sits in. Thought it was odd that they didn't put a metal box image or something mechanical around it, just left it as a blank box. :confused:
I'm a fussy bugger and if those are the biggest moans i've got, Valve have done alright :D
Anybody find the "space that doesn't fit inside it's area" or some such description yet?
