p67 boards crossfire and the only pci slot
14 Oct 2008
London
Anyone have a p67 board crossfiring 69xx AND using the pci slot? - the one at the bottom - NOT the pci-e non gfx slots
I want to know if I can fit my xonar dg in there and use 2 gfx cards.
also - anyone fit a noctua NH-14 in an antec 902?
Something like the MSI P67A-GD65?
If you install 2 double slot graphics cards the bottom PCI slot is free:
Thanks buddy I went for the ASus p67 pro instead it's got two pci slots rather than the tooth's one
You'll only be able to use 1 PCI slot if you have 2 graphics cards installed.
Good luck.
Some of the Asus P67 boards are a bit temperamental which is why I suggested MSI.
