- 2 Dec 2006
Hello there, I own a 480 GTX SE and get reasonable temperatures but I just happened to check out a review of the KFA2 and here you can see a 470 SOC is significantly hotter than the the KFA2 480. The 470 SOC also drains 100w less power than the KFA2 so clearly it should be a lot cooler if the cooling solutions were similar?
Irritatingly the KFA2 can also be found quite a bit cheaper than the SE at sub £200. So tell me, what are your thoughts on which is the best? The KFA2 only has a 2 year warranty also. Anyone else feel like they got snapped up by the deals without really checking what else was around?
http://www.*****.net/content/item.php?item=26757&page=8
