- 13 Jan 2004
- Leicestershire
a lot of you work on your own cars so figured this is the most useful place .
a mate is welding an arch onto a sierra and he keeps blowing holes in metal. He can weld ok as he's put a sill on same car, same day just fine.
what can he do though as hes at a loss.
thoughts are:
the gap is too large - about 2mm in places but touching largely.
in order to sort the about put metal behind it so there's no gap but it still keeps blowing holes in the metal.
tried turning it from high to medium but it still does it.
seems that the metal seems too thin to weld o or temp is too high but tried changing those issues and nothing.
thoughts?
thoughts are:
thoughts?
