looking for a small case to fit full ATX
11 Oct 2009
Hi all,
I'm trying to shrink my current build down as soon I'll be moving somewhere with a lot less space. I'm happy with the current components just need a smaller case than my antec 900.
How does this all look?
Coolermaster Elite 360 Mini Tower Case - Black
Enermax UCTB12 T.B. Silence 120mm Fan x 2 (replacing the one that comes with the case and one for the top/side)
Enermax UCTB8 T.B. Silence 800mm Fan for the 80mm on the bottom/side
Scythe Shuriken BIG Quiet Low Profile CPU Cooler (Scoket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) to replace my current CPU cooler which would be too big
Any advice would be greatly appreciated :)
thanks for the replies
@johnny sublime - no particular budget in mind but will probably need to serve as a HTPC in the living room, so looking for something that'll be reasonably subtle and fit in. that lian li looks pretty swish, something desktop orientated might fit in better I'm currently thinking.
@Marvin - I have a corsair HX520W and a powercolor 5770, not massive but do you think I would have problems?
They'll be fine I'd think. My brother had an Elite 360, and it fit 9800GT SLI in there and a OCZ600W PSU without too many issues (the PCI-E connector was a little squished, and had to be in place before slotting the card in). It wouldn't fit a 4890 though.
I just put my old kit nto a coolermaster 360. took a bit of work as I had to keep taking bits out to fit other bits in I noticed but overall, apart from the cheap plastic emblem on the front that spins around I'm very impressed with it.
Thanks for the reassurance timmy and marvin, I've opted for the elite 360.
I agree that spinning badge looks a bit naff, hoping to remove it (and keep the finish somehow) or stealth it (by painting it).
I haven't really investigated yet but it appears to be on some sort of elstatic. (if you pull it a bit it springs back if I recall correctly).
Will have to have another look with a pair of scissors at hand! :)
