Can you change the of stained glass on a door?
18 Oct 2002
At home
Hi all
Does any one know if it possible to change the colour of stained glass on a front door. It's not proper stained glass like in a church but the kind you get on windows on most front doors if that makes sence?
If it is possible how do I go about doing it ?
Sorry for the confusion I'm not explaining my self well.
I think it is fake as on the outside it's clear glass and on the inside it's as if it has been painted?? Some sections frosted some blue some yellow. But I can feel a slight raise where technically the leading would be altho it is not real leading.
Does that make any more sense? I don't want to replace the glass I thought there might be some way I can remove the colour aand paint a new one?
