Man of Honour
- 29 Nov 2008
- London
Just get wedge, init.
Would having more muscle behind not make the moobs appear to be smaller?
Imagine a jelly on a plate, now imagine a jelly on an 8oz steak next to it.
Which looks smaller?
I would certainly try to drop body fat and build a bit of muscle first, just to eliminate the possibility that it is just unfortunate conventional fat storage.
What I meant was that if you look at people who have plenty of muscle and a bit of fat , the fat doesn't seem as noticable on them compared to people with hardly any muscle so the moobs will appear more prominent
Surely you can't do both at the same time???
Lower bf% while gaining lean mass? Easy.
I thought one required a calorie deficit and the other a calorie surplus.
Hold on. In what world will making the muscle behind the moobs make the moobs look smaller?
Well it will pad out slightly the fatty tissue,
and also a few weights workouts will lead to elevated testosterone levels, decreasing the ratio of estrogen, which will also help matters.
Not really cryptic
if you are putting on more lean mass than you are fat then you will have a lower bodyfat%![]()
I have them but they are muscly not fat, which is odd because I dont do any weight training. They are at least a handful each and bounce when I run, sometimes my nips bleed from chafing on long runs. I've been trying to figure out how to shrink/firm them.
Post a pic up fella.
