Just washed, polished and waxed mates Celica GT4 - VERY SHINY!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Mate at work recently purchased a Toyota Celica GT4 and its paint work was rather tatty, some burning where someone had either mis-used a polisher on it or taken a brillo pad too it and generally the paint looking dated.
So we did the following steps:-
1. Hose car down.
2. Snowfoam the car.
3. Hose car down.
4. Wash car with Meguiars NXT Car wash.
5. Dry car with microfibre.
6. Apply Meguiars STEP 1 paint cleaner and in some areas go over with Meguiars scratch X first.
7. Buff off.
8. Apply Meguiars STEP 2 paint polish.
9. Buff off.
10. Apply DoDo Blue Velvet Wax.
11. Buff off.
12. Autoglym wheel sealant, tyre dressing and give car a final going over with microfibre checking for any missed bits.
3hrs later, sunburnt and knackered here are the results:-
Yes it was hard work but look at the results, remember this car is over 15 years old and apart from the odd bit of tidying up the paint has come up very well and the burn marks on the paint have more or less completely come out and can only be noticed if you know where they are.
I am happy with results and the owner seemed very happy, almost in dis-belief that it came up so well.
Now just keep it clean Chris and get a coat of collonite 476s on in a week or two to lock all that shine in. :)
Enjoy it and when you next wash it you will be amazed at how easy it is to wash off. Hope you enjoyed the ride in the 911 too. :D
At first when I saw the photos I thought "wth, it's got a massive scratch in it", and then I realised it was just the wire fence reflected in the spotless paintwork. :rolleyes: Really nice job there, keep telling myself to do something similar to my car but I never get the time.
Looks good. However the snowfoam probably did squat cos you wet the car first. It's best applied to a dry surface so it sticks and can work its magic :)
I see a lot of argument regarding this, seems to be almost a 50/50 split over whether it works best on a wet or dry car.
I have my suspicions it probably makes virtually no difference at all :p
Very very impressed with the results. The paint is silky smooth now! Will be so much easier to maintain the finish of the car now! Worth taking the time over and the sun burn! :-D
Has it had a 'detail' in the past?
If not that is seriously impressive! I was expecting you to say you had gone at it with a rotary.
Great work.
Great work.
Nope, the paint was heavily marred and full of swirls making it look almost grey in sunlight.
A lot of hard elbow work with the right products and the results have paid off, there is still swirls but far less and the paint has a lot more depth to it now and has that always wet deep gloss look. Not bad for hand. :)
3h between 2 of you? Good going. Looks good.
Spent 5h on my own "black" (Storm Blue) Celica today and even that wasn't a complete clean.
Thats the way every car dreams of being treated in its old age
Whats the rough cost of the car and the products used on it? Does it have over 100k miles done?
very nice indeed.... where do i bring mine to :D :p
