Karcher PresWasher Compatibility
25 Oct 2009
Caerphilly
Afternoon,
After planning a day pressure washing 2 patios I've just found that my pressure washer trigger/gun is dead.
There's plenty on Ebay so finding a replacement isn't a problem...
Anyone know if the triggers are interchangeable and compatible with others models?
I know the connection to the PW is the same, im just wondering about differing pressures from the washer to the trigger....
Some of the earlier nozzles don't fit on current model karchers, i have the K3.99 karcher and my vario lance broke, my then neighbour has a karcher and i borrowed his lance off him and it wouldn't fit.
No they are not, the newer K series has different connectors at both the trigger end and the machine end. The older ones are screw on, the new ones push on with a securing lock collar.
Thanks guys.. and bugger! Time to source the proper trigger and hose then...
