Which 360 Radiator?
4 Dec 2009
Worcestershire
Hiya guys!
I am going to be buying a Corsair Obsidian 800D in the next couple of months and upgrade my radiator at the same time. Now, I have been wondering which radiator would be best for me. I can deal with some noise but I use speakers most of the time and prefer my PC to be as subtle as it can be without temps being my limiting factor.
I have been thinking of using a set of 1250rpm gentle typhoons and undervolting them to give me ~1000rpm. So......which 360 radiator would give me optimal performance at 1000rpm but also performs with faster fans (will turn fans up for benching etc.)?
I have been looking at the XSPC RX360 but I am one of these people who like confirmation before buying :p
Cheers
Or the Coolgate if the drain port suits you (which it probably won't in an 800D due to position, but it's another option)...
I use the RX360 and Vipers in my 800D and they work great, low noise up to about 1000 rpm with plenty left in reserve when you need the extra cooling.
Thanks for all the replies guys! I agree completely with build quality of the black ice radiators. I have a black ice 280 slim in the top of my K62 at the moment but it is just a little too small for my GPU and CPU and temps are still my limiting factor for my overclock :(
I think, after looking at the skinneelabs link I will get either the SR1 or the RX360 depending on availability when I come to buy. If they are both available I think I will go with the RX360 as I like the little XSPC logo on it :p
Got a question for those using the Viper fans on rads as they are 4pin PWM how do you control the speed of them as most fan controllers ive seen are 3pin?
I have 4pin fans on my fan connector :)
Would work fine
