- 20 Apr 2011
- Stoke on Trent
Hi
As the title says, i am wondering if the OC i have put on my sons Sapphire 6950 is safe?
I have the core clock running at 900
The memory clock running at 1400
The GPU voltage is set at 1.200v and i also have the Power Control Settings at +20% (correct me if i am wrong but i think this is a total voltage of 1.420v. I am unsure if this is the voltage at all times or if the +20% is only provided when it is required?)
It is the voltage that i am worried about as i can find no good info on what is a safe voltage for this card.
The GPU temps all seem fine, using a custom fan settings (as the default fan settings seem terrible and too low i feel) the temps stay at no more than 65c in game and under basic benchmark tests.
To get this OC i am using a combination of CCC and TRIxx (from Sapphire) and also loading up MSI Afterburner so that i can see frame rates in game.
I do hope that this OC is safe as it has improved the permanences of this card by over a third according to benchmark testing and has allowed me to set most game graphics to maximum, inc AA and Atmospheric AA and i still get frame rates of 60!. (very impressed with this card!!!)
Also if i up the core clock much over the 900 mark this caused freeze ups, but i dare not increase the voltage to see if this stabilizes things... The memory clock would probably be ok increased too.
(this card is running with its original BIOS as i don't want to do the 6970 flash until i hear a little more about the voltages, etc. or i may just unlock the shaders once i work out how to do this...)
Any advice or opinions are greatly welcomed, so i can sleep at night without fear that the card will "go critical".......
Thanks
Thanks
