**Today Only 26/04/2011** Roccat Arvo Compact Gaming Keyboard and Roccat Kone+ 6000DPI Max Customiza
22 Mar 2011
Cheshire
Roccat Arvo Compact Gaming Keyboard @ £38.94 inc VAT
More space on the desktop without the need to forgo all the usual functions. This and a whole lot more besides is offered by the compact ROCCAT™ Arvo. It’s the first keyboard to offer a gaming mode integrated into the numpad and unique thumbster keys. These three extra keys can be assigned macros or the practical timer function, which can’t be found on any other keyboard on the planet.
SIZE MATTERS
It’s no coincidence that the ROCCAT™ Arvo is part of the ROCCAT™ Smart Desktop Management System. In contrast to other keyboards, it only has a tiny desktop footprint. As a result, neither the mousepad nor mouse will get in your way – plus optimum use is made of the gaming zone. The Arvo is perfect even for arrow key gamers, who prefer to position their keyboards diagonally to the monitor and mousepad, as it doesn’t collide with the monitor or hang over the edge of the desk.
DUAL-ASSIGNMENT NUM PAD
You don’t have sacrifice anything with the ROCCAT™ Arvo. The smaller size has been achieved simply by combining the numpad and arrow-key pad. This means that it has all the usual keyboard functions, yet it takes up considerably less space. It’s easy to switch between normal and gaming mode simply by pressing the mode switch button. In gaming mode the arrow keys are illuminated in blue which means gaming even in the dark isn’t a problem. What’s more, two additional, freely programmable macro keys are available which are positioned for optimum access to the left and right of the arrow keys.
UNIQUE THUMBSTER KEYS
You’ll find three further macro keys positioned beneath the spacebar. These can be individually programmed and can be easily operated using the thumb without being pressed accidently. At last, there’s something new for your thumb to do apart from just hitting the spacebar. From now on you can cast healing or attack spells with your thumb. Another unique function is the ROCCAT™ Timer which allows the time it takes for special items to revive to be timed to perfection in many games. The ROCCAT™ Timer can be executed, paused or stopped to within a fraction of a second.
- Compact Design
- Mode Switch Button
- 3 Programmable Thumbster Keys
- 2 Additional Macro Keys
- Anti-Ghosting
- Medium-Height Keys
- High Durability
- 6 Illuminated Status Keys
- Key Deactivation
- Ultra Effective Non-Slip Base
- 1.5metre USB Cable
Was £45.98 Inc. VAT
Only £38.94 inc VAT.
ORDER NOW
Roccat Kone+ 6000DPI Max Customization Gaming Mouse @ £55.98 inc VAT
With a 6000dpi Pro-Aim Laser Sensor and its integrated Tracking & Distance Control Unit (TDCU), the further development of the prize-winning ROCCAT™ Kone Gaming Mouse has unbelievably more power under the hood. Its maximum precision and ultimate tracking are beyond comparison.
The massive upgrade made to the driver and the introduction of the EasyShift[+] button has also turned the Kone[+] into a real customizable marvel at the same time. No other mouse offers as many configuration options as the ROCCAT Kone[+].
MAXIMUM PERFORMANCE
The revolutionary 6000dpi Pro-Aim Laser Sensor, in conjunction with its 10.5 megapixel resolution and 1000Hz polling rate, offers maximum precision, even transmitting lightning fast mouse movements with up to 30Gs of acceleration and with speeds of up to 200ips (5.08m/s) without loss or lag. Thanks to the Tracking & Distance Control Unit, which is now integrated in the laser sensor, the ROCCAT™ Kone[+] can also calculate the lift-off distance as well as fine-tune the sensor to suit the mousepad. The result: optimal tracking.
ERGONOMIC HYBRID SHELL
The highly praised hybrid shell for right-handers, including the Soft-Touch Surface, have been retained, but really useful core improvements have been made that further increase the comfort of Kone’s successor. The mouse wheel is completely new: distinctive notch positions are perfect for gaming, and the wider design makes it easier to control. The button above the mouse wheel has been made larger and you’ll now find a nicely-sized toggle switch below the mouse wheel. The result: maximum gaming comfort.
22 MOUSE FUNCTIONS
Thanks to the EasyShift[+] button, all the buttons – including the mouse wheel – can be assigned two functions such as macros or other functions. As a result, you now have 22 functions available at any one time instead of the usual 12.
Find out more about EasyShift[+] and just how easy it is to use here: mehr...
4 LED MULTICOLOR LIGHT SYSTEM
Like before, the light system remains unbeaten. Four multicolor LEDs, together with the enhanced lightpipes and configurable effects, can light up, alternate or pulsate in more than four different colors at the same time. It’s a real eye-catcher on any desktop.
5 GAME PROFILES
You can configure your button assignments, including macros, DPI settings, the sensor sensitivity level and your lighting settings too, and save them to any one of 5 profiles on the 576kB of onboard memory. This allows you to customize your mouse to suit individual games. You can associate each profile with a particular application so the right button assignments, DPI and color settings, etc., are automatically loaded when you start the game. When a profile is set as the Windows Profile, the ROCCAT™ Kone[+] will always switch to this profile when you return to Windows after leaving a game or app. Additional profiles can be saved on your hard drive whenever you want, and then loaded to any one of the 5 profile slots using the driver menu.
MACRO MANAGER
Creating and editing your own command sequences is made easy thanks to the highly praised Macro Manager. Predefined macro presets for the top 20 PC games as well as several office apps make it even easier to customize the mouse – plus the new Loop Function now makes it possible to loop macros indefinitely.
SOUND FEEDBACK
The famous ROCCAT voice gives immediate feedback when you change DPI settings, profiles, the volume level or sensitivity setting. As you don’t need to look at an additional display on the screen or on the mouse itself, nothing will distract from the gameplay. It really is as easy at that.
CUSTOMIZE THE WEIGHT
A weight system comprising 4 x 5g weights is included, allowing you to customize the weight in four stages to suit your preferences.
Was £68.99 Inc. VAT
Only £55.98 inc VAT.
ORDER NOW
That's a pretty great deal on the Arvo. I've had mine for a few weeks now, and I'm finding it a big improvement over the Saitek Eclipse II, especially in terms of how much desk space it's freed. For anybody looking for a compact gaming keyboard, it's a solid choice.
Are you kidding me? i ordered this keyboard on friday @ £46... and i've not even recivied it yet.. and now you drop it to £38... Charming.
Easy fix return it, Reorder it. problem solved. It's not even here yet i can just refuse the delivery.
They did that to all the people who pre-ordered the 650D *BROKEN* cases. We didn't get the corsair fix and had to go through corsair to get them and they dropped the price by £5 within a few days of us receiving them.
More on topic, that keyboard looks quite nice.
