- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey all
I have priced dropped the Zaward fans whilst current stock lasts.
With prices starting at only £6.98 inc. VAT your system can be cooled better and more efficiently. These fans offer excellent airflow and low noise levels due to the Golf Ball dimple design.
Zaward Golf II 140mm x 25mm Fan - Black @ £7.99 inc VAT
With unique patented golf dimple blades, these fans can reduce noise levels by up to 15% and provide high aiflow for excellent cooling performance.
- Unique patent Golf dimple blade reduces 15% noise level at the same RPM & airflow
- Low Noise level from 10~20.8dBA depends on fan speed
- Long life expectancy of 60,000 hours in 40 degree C
- It increases fan's efficiency and reduces current consumption
- PWM function supported, starting at low speed minimizing with very low noise level without reducing efficiency
- Dimensions: 120 x 120 x 25mm
- Fan Speed: 900 RPM
- Air Flow: 62.14 CFM
- Noise Level: 10 - 20.3dBA
- Life expectancy: 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 140mm x 25mm PWM Fan - White @ £7.99 inc VAT
- Low Noise level from 10.1~20.3dBA depends on fan speed
- Dimensions: 140 x 140 x 25mm
- Fan Speed: 300 -1200 RPM
- 74.14 CFM
- Noise Level: 10.1 - 20.3dBA
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 140mm x 25mm Fan - White @ £7.99 inc VAT
- Unique patent Golf dimple blade reduces 15% noise level at the same RPM & airflow.
- Low Noise level from 10~20.3dBA depends on fan speed.
- Long life expectancy of 60,000 hours in 40 degree C.
- It increases fan's efficiency and reduces current consumption.
- 62.14 CFM
- Noise Level: 20.3dBA
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 120mm x 25mm PWM Fan - Black @ £7.99 inc VAT
- Fan Speed: 300 - 1300 RPM
- Air Flow: 56.05 CFM
- Noise Level: 10 - 20.8dBA
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 120mm x 25mm PWM Fan - White @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Blue / White @ £7.99 inc VAT
- Sleeve bearing design extends ultra long life and enables lower noise level
- 7 dimple blades raise airflow and air pressure at the same noise level
- Able to convert small 3 pin to big 4 pin 12V input connector
- Fan Speed: 1200 RPM
- Noise Level: 17dBA
- Aitr Flow: 48.48 CFM
- Life Expectancy: 26,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Blue / Blue LED @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Red / White @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Clear / Blue LED @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - White @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Zaward Golf 120mm x25mm Fan - Black @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
- 74.14 CFM
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
- 62.14 CFM
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £6.98 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £6.98 inc VAT.
ORDER NOW
Only £6.98 inc VAT.
ORDER NOW
They are both priced similarly and have similar specs too, well they should do considering they employ the exact same design.
