Switching from ATI to Nvidia
29 Aug 2010
Cornwall
Hi,
I'm planning to upgrade my rubbish, slow single 5870 ;) to 570 SLI.
I don't want to have to do a fresh install of the OS, so what's the best way to deal with the drivers?
Is it as simple as just uninstalling the ATI/AMD drivers, turning the PC off, switching the cards and then installing the Nvidia drivers when the pc restarts?
Or do I need to use some driver cleaner?
I've heard these can cause more problems than they solve?
If I should, which one is best?
Thanks.
I'd do as you suggest, uninstall the ATI drivers, shut down, install cards and install the NV drivers. I know bog all about SLI though
I have always just uninstalled the old drivers, rebooted with new card then install new drivers.
What motherboard are you using.
I changed from a 5970 to GTX460 SLI recently, and just uninstalled all the AMD drivers, changed the cards over, then booted and installed the Nvidia drivers. Very easy. You shouldn't need to bugger about with driver sweeper.
I'm planning to remove the stock HSF from the (reference design, Sapphire) 5870 and attach an EK waterblock.
It seems like there could be quite a lot of scope for things to go wrong, anyone got any tips?
Thanks.
went from ati to NV recently- Uninstalled all ati drivers, cleaned reg edit, plugged NV card and installed new NV drivers!
2 X 2GB 6950 ref 1 unlocked to 6970 shaders/sclocks are faster/scale better and much cheaper than 570 sli.
6950 xfire V 570 sli:
6950 can then be unlocked and oc, 570 can be oc too.
You say that but you don't know how much I paid for my 570s.
Also, I already have the 570s so using them is cheaper than buying 6950s.
Also, when I got my 570s there was a lot of talk around the heat and the noise of the 69X0 cards. The 570s seemed to be reported to run cooler and quieter.
If I was buying them now, I'd probably look into a couple ref 1 6950s with 3rd part coolers.
Just run the ATI uninstall manager and choose "Express Uninstall". Did it when swapping out my old HD4890 for a GTX470 and everything ran flawlessly the moment I booted up for the first time with the new card.
Anyway, driver cleaners could cause issues.
i have a Q to those who moved from ATi to Nvidia:
did you notice any difference in image quality ? years ago when i moved from Nvidia to ATi i noticed right away that the ATi card has noticeably better image quality for games & movies,is this still the case now ?
i have also noticed xbox360 (which uses ATi) has richer smoother image than Ps3 (which uses Nvidia gpu). so i'm thinking its still the same.
Remember the PS3 and Xbox use way outdated GPUs, so the difference could be there because of that. Also remember that most games on consoles are developed with the Xbox as lead platform, then ported to the PS3 and PC.
And, no I don't think there's a difference.
Nope it isn't. No such difference to be honest, it's just a question of tweaking and resolutions.
Were they cheaper than £192 each?
:D
Like I have done, AC extreme 5870 coolers doing a stunning job on my 6950>70's:D
No, but I bought them a while ago, before the VAT change I think. so not sure you'd get new AMD 6950s for £192 either. I think they were around £220 at the time.
Or even just the ones that come with the Twin Frozr II or something like that.
ok thanks for the reply guys thats good to know :) but i have decided to stick with ATi (hd 5850 costs nearly half the price of a similar performance Nvidia card) even though i would have liked to try Nvidia's 3D.
IF bulldozer is WORTH upgrading to then i might get a Nvidia card for my bulldozer upgrade. :)
How much did yours cost? Just curious how much you got them for.
You can get the Asus one today only for £192 if you have a look, you can get the 2 Gb 6950 nearly every other day at that price or there about.
It cost me £412 for my xfire, the lowest I've seen the 2 Gb 6950 go for is £176 each.
On the subject of driver removal, I still have nvidia drivers installed as I was using hybrid physx and I don't have any problems at all.
