4pin ATx On Asus P8p67 Pro MOBO
11 Apr 2011
Nicosia, Cyprus
Please guys im really really confused now last time my Mobo just shut down it self and never worked again and i will receive a new one tomorow and im wondering if it was my psu that burn my mobo and also if i had to change it since it only have a 4pin atx 12v (my osu is 550watt artic cooling fusion 550R) ...im interested of OC a liitle bit my sandy i7 2600k to 4.5Ghz Max and Max vcore =1.35 no more otherwise i will lower my clock
so please guy give me some advise on what should i do or did i need to change it or is a 4pin atx is enough for my target OC???
please help
My Gpu is a ati 5870, 4 Gb Gskill DDr3 1600mhz , 1 DVD RW, 1x1Tb WD 7200 rpm, 1x 150Gb velociraptor 10000rpm i that is all,,with 3 fan 120mn
The Asus P67 boards will work with a 4 pin connector, so you should be ok to get it setup and running. I doubt this causes your original board to break.
Whether or not your PSU is good enough for your target OC I'll let someone else answer :)
Ok thx but tell me i see that your using an asus p8p67 and inel sandy B, so are you using a 4pin or a 8pin ?,and are on OC thx
I'm using a 4pin and whilst i'm running at stock now, i can overclock to 4.3 without issues. I didn't try and go higher as I'm using the stock intel heatsink and started having temperature issues.
I don't have a good PSU (just a cheap 550w one) but i also have a less powerful graphics card (Radeon HD 5550).
OK THX
