Palit GeForce GTX 560Ti 2048MB Worth the extra VRAM?
31 Dec 2007
The TARDIS, Wakefield, UK
Hi
anyone got a Palit GeForce GTX 560Ti 2048MB ?
retails for about £215 is it worth buying for the 2048mb ?
Also whats the noise levels like.
No it is not worth the extra 1GB of VRAM at your resolution:
http://www.anandtech.com/bench/Prod...3.216.219.221.228.229.230.231.232.233.234.235
I would get the GB SOC 560 instead, neck in neck performance with a standard 570:
http://www.guru3d.com/article/gigabyte-gtx-560-ti-soc-review/
http://www.legionhardware.com/articles_pages/gigabyte_geforce_gtx_560_ti_soc,1.html
Comparison of some of the 560s:
http://www.hardwarecanucks.com/foru...tx-560-ti-roundup-asus-evga-gigabyte-msi.html
EDIT:
Nearly all of the 560s (especially the MSI and GB ones) are extremely quiet at idle and load, that's one of the main things I like about these cards.
1gb is fine for 1080p, 2gb is only needed on a select few games like crysis and arma 2 or quite a few more if you're forcing a decent amount of sgssaa anti aliasing. for triple screen though 2gb is absolutely needed
