Okay, I have no idea why your GPU is at 98.5°C then. I'm obviously assuming there's no other card blocking it or anything.
Good luck selling a card that can't maintain decent temps at stock though...
well my 6970 runs 98.5c @ stock fan speeds in crysis2 and any other dx9 game , so do they run hotter that that ?
Won't you receive a card back though? I'd just stick with it to be honest. The grass is no greener on either side.
i will be rma'ing it so i need a card to use , got £200 spare so i thought about the gtx480
Am Very tempted to try the standard Gigabyte GTX 480 with them being only £166
I'm pretty sure he doesn't have to pay VAT due to where he lives.
That said, I wouldn't recommend the standard GTX 480 (unless you plan to remove the stock cooler and WC it) as it is rather loud and hot. This one for £191.66 would be a much better bet.
I was planning to get 480 SLI and put one under water a the other one was a SOC but GB gave me a 580 as a replacement![]()
Wow, that is some nice customer service
May I ask how long your turn-around time with the gigabyte RMA was?
Unless your names CleeecoooThat's just bonkers imo spending £200 on a very similar card
Needs to exhaust the heat out the case,As i would be putting it in a small HTPC caseThat said, I wouldn't recommend the standard GTX 480 (unless you plan to remove the stock cooler and WC it) as it is rather loud and hot. This one for £191.66 would be a much better bet.
(the Gigabyte with the 3 fan cooler would be no good..)
