i'm too scared of bricking the card to flash, so i prob just leave it and get a shaman later unless theres another solution but thankyou your help
I've looking into flashing the bios, and it seems easy enough to lower the minimum speed to 5%, which should make it completely silent. Fermi bios editor looks very easy to use, and I can only see problems if there's messing about with voltages or clock speeds in the bios. Safer to use Afterburner for that anyway, and then I could use a custom fan profile in Afterburner to start at 5% and increase the fan as temps rise.
I'm waiting till KFA2 get back to me after the weekend (hopefully), before I take anything on though.
I'll keep you posted.
edit: I'll also add that even with the fans turned off, the card never went above 34 degrees at idle for me, and that's with all the case fans off just now in a closed case while I was trying to get to the root of the noise. So there's no reason for these fans to be running so fast that you can hear them to keep this card cool at idle.
edit2: Contacted Arctic Cooling too
