I'm going to be getting a new motherboard and I can't decide which to get. The choices are:
MSI Big Bang Marshal
Asus ROG Maximus IV
Gigabyte P67A-UD7
I'll also be getting an AMD 6990 overclocked, Corsair AX1200, Intel 2500k @ hopefully around 4.8GHz and the gpu and cpu will be under water (maybe mobo in the future).
One question I do have is about the Asus and Gigabyte boards. They are both equipped for 3-way SLI/Crossfire. With the 6990 being dual gpu, does that mean I won't be able to put another 6990 on the board in the future? Or is it referring to the fact that you can only fit 3 cards on the board and could essentially have 3 6990s on there (not that I will ever have 3 of them)?
Out of the 3 boards, I prefer the looks of the maximus. However, the GPU spacing and upgradability on the marshal is great. I think I'd like to go for the maximus but am worried about the question above. Also for the price of these boards I could go X58 and get an Asus Rampage III Extreme which is a godly board, but seeing as I'm buying everything and not just upgrading from x58 I'll be better off going for P67 right?
Thanks guys
Asus ROG Maximus IV
Gigabyte P67A-UD7
Thanks guys
