Hi there
As usual OcUK is leading the way with some truly epic deals on Asus and MSI graphics card, these prices are valid until 6th May 2011:-
Asus ATI Radeon HD 6950 DirectCU II 1024MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Speed up heat dissipation with 600% more airflow via exclusive DirectCU with dual fan design
- Expand your visual horizon across six monitors with four native DisplayPort outputs
- Super Alloy Power technology delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- Crank up 50% faster clock speed with exclusive Voltage Tweak
- ATI Reference Design (Revision: 1) - Flashable too 6970
- Core Clock: 810MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 3 Years
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6950 OC 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
Features:-
- Memory: 2048MB GDDR5
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£219.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6950 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card @ £224.99 inc VAT
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£239.99] Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6970 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
Based on ASUS DirectCU architecture, which uses copper heat pipes in direct contact with the GPU to speed up heat dissipation for over 20% cooler performance, DirectCU II takes cooling further with twin 100mm fans for 600% airflow. Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan. Full throttle overclocking with exclusive ASUS Voltage Tweak via Smart Doctor – boosting 50%* more speed, performance and satisfaction!
Features:-
- Core Clock: 890MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 3 Years
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Features:-
- Core Clock: 800MHz
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Card Dimension(mm) 275*110*38mm
- Warranty: 2 Years
Was [£209.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 Twin FrozR II 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£224.99] Inc. VAT
ORDER NOW
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £224.99 inc VAT
Features:-
- Core Clock: 850MHz
- Memory Clock: 5200MHz (Effective)
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
MSI ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £249.98 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£269.99] Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6970 Lightning 2048MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
nonl2br
<img src="http://uk.msi.com/marketing/images/AMDLightningStatic.jpg" alt="MSI Lightning" /><br>
<br>
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled N580GTX Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records! <br>
<br>
<Font size="5"><b>Key Features</b></font><br>
<br>
<img src="http://uk.msi.com/marketing/images/power4.png" width="210" align="left" alt="power4" /><b>Industry-leading Power4 Architecture for Overclocking Reliability</b><br>
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there. <br>
<br>
<img src="http://uk.msi.com/marketing/images/lightningsplit.png" width="210" align="right" alt="Cooling" />
<br>
<b>Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level</b><br>
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.<br>
<br>
<img src="http://uk.msi.com/marketing/images/afterburner.png" align="left" alt="afterburner" /><br>
<b>Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage</b><br>
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
<b>King of Extreme Overclocking</b><br>
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking<br>
<br>
<img src="http://uk.msi.com/marketing/images/mcii.png" align="right" alt="Military Class" /><b>Carefully Selected Materials</b><br>
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
<br>
<br>
<img src="http://uk.msi.com/marketing/images/MUSTHAVE.png" alt="Kit Guru Gold" />
<br>
<br>
<Font size="5"><b>Specifications</b></font><br>
<br>
<b>Stream Processors</b> - 1536 Units<br>
<b>Core Clock</b> - 920 MHz<br>
<b>Memory Clock</b> - 5500 MHz<br>
<b>Memory Size</b> - 2048MB GDDR5<br>
<b>Memory Bus</b> - 256 bits<br>
<b>Output</b> - Mini DisplayPort*2 / HDMI / DVI*2<br>
<b>TDP</b> - 269 W<br>
<b>Card Dimension</b> - 310x127x40mm<br>
<b>Form Factor</b> - ATX<br>
<b>DirectX 11</b> - Y<br>
<b>OpenGL 4.0</b> - Y<br>
<b>CrossFireX</b> - Y<br>
<b>Eyefinity</b> - Y<br>
<b>AVIVO HD</b> - Y<br>
<b>PowerPlay</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
- World’s first 18 phase PWM on HD 6970.<br>
- Independent Memory Power support. <br>
- Copper MOS with 2x high current capacity. <br>
- Proadlizer*4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter. <br>
- Propeller Blade technology for 20% more airflow. <br>
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation. <br>
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- Support voltage adjustment of GPU/Memory/VDDCI<br>
- Military Class II Components for longer product lifespan. <br>
- LPL (Lightning Power Layer) for the stable power supply.<br>
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!<br>
Was [£329.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6870 OC HAWK 1024MB GDDR5 PCI-Express Graphics Card with FREE Lara Croft Game **Pre-Order ONLY Price** @ £149.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 930MHz
- Memory Clock: 4200MHz (Effective)
- Processing Cores: 1120
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with Lara Croft Guardian of Light PC Game
Only £149.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £399.98 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was [£419.99] Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
MSI GeForce GTX 580 OC Twin FrozR II 1536MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Nickel-plated Copper Base: Large size of Copper Base can dissipate the heat of GPU faster.
Dual 8CM PWM Fans: Dual fans provide double air flow. Air flow from dual fans can cool down whole module at once.
Five heat pipes with SuperPipe Technology: Five heat pipes can provide faster heat dissipation.
Form-in-one heat sink: Form-in-one heat sink covers the memory and power module
19ºC cooler and 8.4dB quieter compared to reference design
Features:-
- Core Clock: 800MHz (Fermi GF110)
- Memory Clock: 4096MHz (Effective)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£399.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
MSI GeForce GTX 580 Lightning 1536MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
nonl2br
<img src="http://uk.msi.com/marketing/images/NVLightningStatic.jpg" alt="MSI Lightning" /><br>
<br>
<br>
<br>
<br>
<br>
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 21°C lower than the reference board when the N580GTX Lightning are operating under full loads. Fan noise is also 5dB lower in addition to having much higher overclocking potential.<br>
<br>
The MSI N580GTX Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of N580GTX Lightning is 30% higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
For hardware enthusiasts, the MSI N580GTX Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios and XtremeCool switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the N580GTX Lightning the ultimate graphic cards for extreme overclocking<br>
<br>
The MSI N580GTX Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
<br>
<br>
<img src="http://uk.msi.com/marketing/images/GOLDAWARD.png" width="150" alt="OC3D Gold" /><img src="http://uk.msi.com/marketing/images/PERFORMANCEAWARD.png" width="150" alt="OC3D Performance" />
<br>
<br>
<br>
<b>CUDA Cores</b> - 512 Units<br>
<b>Core Clock</b> - 832 MHz<br>
<b>Shader Clock</b> - 1747 MHz<br>
<b>Memory Clock</b> - 4200 MHz<br>
<b>Memory Size</b> - 1536MB GDDR5<br>
<b>Memory Bus</b> - 384 bits<br>
<b>Output</b> - DisplayPort / HDMI / DVI x 2<br>
<b>TDP</b> - 260 W<br>
<b>Card Dimension</b> - 305x127x45mm<br>
<b>CUDA</b> - Y<br>
<b>SLI</b> - Y, 3-Way<br>
<b>PhysX</b> - Y<br>
<b>PureVideo HD</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
- World’s first 16 phase PWM on GTX 580.<br>
- Independent, dedicated Memory power support. <br>
- Proadlizer x 4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 21C cooler & 5.5 dB quieter. <br>
- World’s first GTX 580 graphics card supporting voltage adjustment of GPU/Memory/PLL.<br>
Was [£439.99] Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
Features:-
- Core Clock: 770MHz
- Memory Clock: 4000MHz (Effective)
- Shader Clock: 1540MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was [£289.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti 1024MB GDDR5 PCI-Express Graphics Card @ £174.98 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 830MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 830MHz
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1660MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was [£199.99] Inc. VAT
Only £174.98 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
nonl2br
<img src="http://uk.msi.com/marketing/images/560tfiibanner.jpg" width="768" alt="Hawk" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>Twin Frozr II Thermal Design 20 Degrees Celsuis Cooler!!</b><br>
- Dual 8CM PWM Fans for 50% more air alow can cool down GPU/Memory/Power Module at once.<br>
- Four heat pipes with SuperPipe Technology<br>
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.<br>
<img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf01.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf02.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf03.jpg" align="centre" width="220" alt="Triple Over Voltage" /><br>
<br>
<b>7+1 Phase PWM Design</b><br>
- Higher current to GPU Powerv
- Higher overclocking capability<br>
- Better stability in peak load <br>
<br>
<b>Military Class Components</b><br>
- Hi-C Cap provides more precise GPU voltage.<br>
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.<br>
- All Solid CAP for longer lifespan. <br>
<br>
<img src="http://eu.msi.com/pic/feature/features_20091001175702.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s113_20080924184632.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s114_20080924184756.gif" align="left" alt="MSI" />
<img src="http://www.msi.com/pic/feature/features_20101116171850.jpg" align="left" alt="MSI" /><br>
<br>
<br>
<br>
<br>
<br>
<BR>
<BR>
<br>
<font size="4"><b>Specifications</b></font><br><br>
- Dual 8cm PWM Fans for 50% more airflow.<br>
- Superpipe technology and nickel-plated copper base for better dissipation<br>
- 20c cooler than reference design<br>
- Military Class II Components<br>
- Core Clock: 822MHz <br>
- Memory: 1024MB GDDR5<br>
- Memory Clock: 4000MHz (Effective)<br>
- Memory Interface: 256-Bit<br>
- Processing Cores: 384<br>
- Shader Clock: 1644MHz<br>
- Bus Type: PCI-Express 2.0<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready <br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 4.0 Support<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
- 3D Vision Enabled<br>
- NVIDIA Surround Enabled<br>
- Warranty: 2 years<br>
Was [£194.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Asus GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with FarCry 2 & Operation Flashpoint Games @ £199.99 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- Core Clock: 700MHz
- Memory Clock: 3696MHz (Effective)
- Shader Clock: 1401MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
- Supplied with FarCry 2 & Operation Flashpoint: Red River PC Games
ORDER NOW
These are incredible deals and I shall be holding these prices until 6th May 2011, so get your wallets out.
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
ORDER NOW
Features:-
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
nonl2br
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<b>HDCP</b> - Y<br>
<br>
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
nonl2br
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<b>CUDA</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
ORDER NOW
Features:-
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
ORDER NOW
nonl2br
<br>
<Br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<BR>
<BR>
<br>
- SLI Ready <br>
- HDCP Capable<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
ORDER NOW
- was going to get them elsewhere until I saw you had lowered the price.
