Panasonic TX-P42U30B vs TX-P42S20B
30 Aug 2004
Sheffield
Hi All,
I'm just looking for a bit of advice really.
I've found the TX-P42U30B for £462.90 on the Internet, which seems like a great price for a 42" Panasonic Plasma, however I can't find any review on it. I'm assuming this is because it's a 2011 model.
However, I've also been able to find the Panasonic TX-P42S20B for £499.99 - which I've been able to find loads of great reviews for (being a 2010 model).
Therefore, I'm just wondering if anyone has had any experience with this TV and if so, which one is the better model?
Cheers,
MonkieMann
OP
30 Aug 2004
Sheffield
Thanks, I've been doing some research on the TX-P50U30B (the 50" version on the TX-P42U30B) and that appears to be the lower range 2011 model so I think I'll give that one a miss too.
I'm now looking at the TX-P42G20B which seems to get great reviews, however it is quite a bit more expensive, but will probably be worth it.
7 Dec 2010
Leeds
I picked up a TX-P50G20B last week for £599 from the local panasonic store. Great TV ..
Is a 50" too big for your needs ? It's a great price at moment for them while they last at the store you will need to tell them to do a price match otherwise its £899.. found the 42 in google shopping for £515 which I still think is a bit much if the 50" is only £85 more.
OP
30 Aug 2004
Sheffield
That sounds awesome, a 50" would be ideal actually, I just didn't realise you could get them so cheap! I've emailed you trust email address for some more information. Is that okay?
Cheers
