New build/few old parts
9 Jul 2009
Jersey C.I.
Hi I have few old parts from my old pc and I need new mb,cpu,memory.
Old parts:
2x Radeon HD 4870 X2 in crossfire
Tagan 1100-bz
OcUK Custom WaterCooling Kit (EK Supreme Acetal CPU Block, EK 1/2" Hose fittings, XSPC Bay Reservoir & Pump, Alphacool NexXxos Xtreme I Rev2 & Accessories)
1TB Samsung Spinpoint F1 32MB Cache SATA-2 Hard Drive
LG GGC-H20L Blu-Ray/HD DVD±RW Dual Layer ReWriter (Black)
and now new parts:
MB
Asus P6T Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
OR
Asus Rampage II Extreme Intel X58 (Socket 1366) DDR3 Motherboard
OR
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
Cpu
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366)
OR
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366)
OR
Intel Core i7 930 2.80GHz (Bloomfield) (Socket LGA1366)
Memory
I don't know any suggestions
And now the most important if my graphics cards will work together with these motherboards without any problems??
Sandybridge mate.
its a newer tech, faster, cheaper.
i5 2500k vs i7 950 - http://www.anandtech.com/bench/Product/288?vs=100
add a dual channel memory kit - http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS&groupid=701&catid=8&subcat=1517 - unlike the socket 1366 which needs triple channel ram.
stick it all in a motherboard - http://www.overclockers.co.uk/showproduct.php?prodid=MB-165-MS&groupid=701&catid=5&subcat=1906 - that is in stock and does crossfire/sli at equal speeds per PCI-E slot.
Does your water cooling kit have a Intel socket 1156 mounting kit? socket 1156 and 1155 use the same mounting kit.
A few questions maybe stupid but I do not know?
my two graphics cards will work on this mb??
4gb is enough??
my old motherboard is a Asus Rampage Formula Intel X48 (Socket 775) and the processor is the Intel Core 2 Quad Xeon X3350 2.66GHz Quad Core so I do not think block fit to the new3 mb?
yes
4gb is enough??
yes
Depends what mounting kits came with it? if you dont have a socket 1156, then it wont fit
Ditch the competitor link dude.
But I can see how that block has the same shape as the mounting plate you found, so looks like a winner:)
Cant see why not.
Even on the rare of chance that the waterblock doesnt fit, the cpu comes with a heatsink with thermal paste pre-applied so you can get it working anyway.
And thats another thought, do you have thermal paste to attach your waterblock to this new cpu?
