Coolermaster cm690 and venom cooler?
28 Apr 2011
I'm planing to use a coolermaster cm690 II Dominator lite in my build.
I'm worried that I might have clearance issues with the Akasa Venom cpu cooler.
Has anyone used this cooler in this case and had any problems?
Also can anyone confirm it has a blue led front fan as shown in the picture on the OC site as it doesn't list it as led in the discription.
Thanks in advance!
I have both the case and cooler, the only thing you won't be able to use, is the top side fan. I have blocked all the holes in the side panels using duck-tape and its given me better airflow through the case.
