- 28 Apr 2011
Its blue, and there is a switch on top to turn on/off
Cheers!
Ethernet cables not an option unfortunately.
You got a good star alignment when you fitted the card then![]()
only thing i can suggest is to change the motherboard to a gigabyte/MSI equivilant, because some people have been having problems with the asus motherboards:
this would be best if it was available: http://www.overclockers.co.uk/showproduct.php?prodid=MB-170-MS&groupid=701&catid=5&subcat=1906
but its been on preorder for forever and a day, so im going to suggest this instead: http://www.overclockers.co.uk/showproduct.php?prodid=MB-324-GI&groupid=701&catid=5&subcat=1906
other than that, it looks great
What sorts of problems with these motherboards?
Can't see the point in a £200 560Ti, when a £200 6950 (unlockable to 6970) will pee on it from a great height.
its does is some games but not in others http://www.anandtech.com/bench/Product/293?vs=330
We can see that enabling the shaders without any clock increases improves performance. Once the clock speeds are adjusted to match the HD 6970, the card effectively performs just as well as a full blown Radeon HD 6970.
Cheers!
Ethernet cables not an option unfortunately.![]()
What would you suggest instead of the TP Link?
Thanks for the advice so far guys, really helps!
So the question is Nvidia or ATI?![]()
Theres a thread here - http://forums.overclockers.co.uk/showthread.php?t=18261244
You should get this motherboard - http://www.overclockers.co.uk/showproduct.php?prodid=MB-167-MS&groupid=701&catid=5&subcat=1906
its cheaper and has the newer UEFI BIOS, surprised Reaper 392 didnt link to it.
Cheers fella!
Just wanted to check was the MSI C45 part of their classic series?
I thought the C stood for Classic instead of gaming?
would I be better off going for a GD53?
http://www.overclockers.co.uk/showproduct.php?prodid=mb-169-ms&groupid=701&catid=5&subcat=1906
