- 30 Dec 2005
- Calgary
My point is and always has been that the "solutions" arriving at 1 are wrong, because they are not following the standard order of operations.
If you want to throw that out of the window and ignore the fact that it is how expressions should be processed, then fine - you're right, it is ambiguous.
But if you do follow the standard order of operations, the solution isn't ambiguous.
It's not ambiguous if you use a rule designed to teach 15 year olds still using the division symbol, but it is ambiguous to anyone with greater education than that, who would write out the equation properly.
