Will OCUK ever sell prebuilt watercooled pc's ?
18 Oct 2009
Wakefield
i already have a water cooled pc but im looking to buy another one, i have bought prebuilt pc's from here before and they was pretty good so if they sold water cooled systems i think they would be pretty well built too.
Have you seen OCUK build logs of all the custom PC's that have been built for customers? these include many water cooling computers.
i had a look at the store system and builds and couldnt see any, ill go take another look
also when i say water cooled i dont mean h50/60/70 i mean propper water cooling
I dont mean H50 etc either;)
Your best bet is to search for threads started by either Nathwraith or rjkoneill and you will find custom builds using water for customers.
They have done in the past, as time goes on they might do some more.
But there watercooled section is lacking fittings ect.
OCUK used to sell a prebuilt called the Ultima Hydrophobia, which was an overclocked i7 950 with a Corsair 800D case with a full watercooling set. The 800D's out of stock at the moment, which is probably why it's been taken down, but if you rang them up I can't see them turning down business.
OCUK also had a watercooled 800D for around £400'ish, just case and watercooling (including I think GPU cooling, though I could be wrong), hope they get these back in soon too.
all our systems can be configured however you want them
depends on how mental you want to go.
heres a small sample of some of our custom water builds in the past...
give sales a call and they will probably put you onto Nath so he can get the cooling right for you
the reason we dont do a great deal of WC focussed builds at the moment is because everyone wants sandybridge and those cpus dont really need custom water.
all complex builds are done by myself, check out my system link in sig for an overview of what i think a watercooled pc should look like ;)
Rjk is bang on the moneyt with watercooled system. there isn't enough demand for them at the moment however we can spec you up any system you want.
Best to give me an email in my trust if you want me to run you a quote :)
