Jesus, some of you people are idiots and need to go back to school.
Its a poor use of brackets...Jesus, some of you people are idiots and need to go back to school.
Its a poor use of brackets...Even if you parse the 'improperly written' version (ie with the division symbol) properly (the standard order of operations), you get the right answer: 9
This is the stupidity of the whole thing. It is insane.
I have replied to it. BODMAS isn't entirely correct just like a lot of things we were taught as children isn't entirely correct (electrons flowing through a circuit, for example). I was taught this as I was taught BODMAS.For the upteenth time, the people disagreeing with you were taught the same thing but don't think of it as all-encompassing God-given 'rule' that you do.
Once you start replying to that we might be getting somewhere, although I do suspect at this point only voltage-therapy may be able to persuade your kind self that you might not be completely 100% right as always.
You can, because there is a rule to follow:Because the problem doesn't clearly show whether we should be multiplying by (1+2) or its reciprocal, you can't say which answer is right.
just like I have a problem with any kind of wilful ignorance.
I don't give a crap who has what degree, GCSE or PhD. Having a qualification has never, ever stopped people being wrong abut something.
Standard order of operations:
1)terms inside parenthesis
2)exponents and roots
3)multiplication and division
4)addition and subtraction
Why can't people just discuss it without calling each other retards and idiots? Calm down folks, it's an equation....
You've followed it wrongly - the rule states you go left-to-right. You did step (3) right-to-left.1) 1+2 = 3
2) na
3) 6/(2*3)
4) 1
Following that rule![]()
I am saying it is definitely wrong, because we have a universally accepted way of parsing expressions and you can only get an answer of 9 when following it.No one is saying that 1 is definitely correct and 9 is definitely wrong, they are saying it is ambiguous and the problem is written in a bad way, and that people with education higher than GCSE maths would probably interpret the equation to give an answer of 1.
I think what we can conclude is that those with a rigid adherence to year 10 rules get 9, and those who have ever used maths for anything even remotely applied think the question is ambiguous.
http://en.wikibooks.org/wiki/Algebra/Order_of_Operations#The_Standard_Order_of_Operations
Just like there is a rule to parse roman numerals, there is a rule to parse expressions.
The way it is written here is only a problem if people don't know how to properly parse expressions.The problem is written in such a way that it is ambiguous whether the reader should multiply by (1+2) or by its reciprocal. Because of this you can't be sure whether the answer should be 9 or 1. Of course it is more likely to be 9, but that doesn't necessarily make it so.
Anyone with experience above year 10 should be familiar with the standard order of operations, which can only give the answer of 9 when followed. If they're not familiar with it and get an answer of 1, they should get familiar with it and try again.I think what we can conclude is that those with a rigid adherence to year 10 rules get 9, and those who have ever used maths for anything even remotely applied think the question is ambiguous.
And its those year 10s who say 'zomg you iz so stoopid! derpy de derp'
