Poll: 6÷2(1+2)
6/2(1+2) = ?
  • 9
    Votes: 516 68.9%
  • 1
    Votes: 233 31.1%
  • Total voters
    749
No, there is nothing "usual" about it. Not once during my degree did I ever see anything written as ambiguously as 1/2x or 1/2(x). It would ALWAYS been written as a fraction.
Both are valid, the only thing "wrong" is the question.
Well that because it won't arise in mathematics - unfortunately lots of programming languages/calculators etc.. require you to enter equations using an operator to represent division and that is what we're talking about - an expression on one line using '/' to represent division.
People have considered how to use '/' to represent division - there is a usual way to consider it and it isn't ambiguous.
6/2(1+2) is the same as (6/2)(1+2) and not generally to be read as 6/(2(1+2))
I agree with you, but http://en.wikipedia.org/wiki/Order_of_operations
I figure if everyone takes a moment to spam this as often as possible, eventually the thread will just spawn the correct answer. So far only Hatter's been rabid & persistent in repeatedly posting the same link over and over again - he needs help.
We can get a definite answer to this, we just have t be stubborn enough.
No I haven't. / is the divide symbol. I have typed the question exactly as I was given it.
You have assumed that everything past the / should be divided, but some would argue that there are three separate terms and so you should only divide the second term as the third term is a separate operation.
Absolutely.
I'd imagine in computer science though, you'd see things like 1/2x fairly regularly though and would have a rule to deal with it. I think that's why certain people are getting very cross :D
No one should get 1 from that... Even if you think the sum is worded badly common sense should prevail.
LoL @ wiki:
It's meant to be
But that is not what the question says. If you type the question into MathCAD, you get 1. If you add a space after the 2, taking the bracket term outside the denominator, then you get 9. There is no space, as such, MathCAD treats the 2(1+2) in the same way as for example 6/2a, rather than 6a/2. The question is ambiguous, and both answers are correct depending on whether you see the brackets being a coefficient of the denominator, or separate and thus part of the numerator.
Exactly, and I believe it to be equally valid an assumption as the other.
That is because MathCAD, in that example, doesn't apply the standard order of operations. It requires you to be explicit.
Just because a calculator doesn't apply the standard order does not mean the question is ambiguous, unless you're going to call every question ambiguous where someone/something is wrong as opposed to right.
It has nothing to do with computer science either. You can replace 6,3,2 by x,y,z from any group with multiplication defined and it is the same.
So you're saying if we let:
x=6
y=2
z=1+2=3
Then we write our equation as x/yz
The answer is still 9? ;)
The notation is poor. I don't know a thing about programming but I do know a thing or two about maths and I can tell you that the notation is rubbish. Whoever wrote this might get away with it in a computer program but not everyone will understand it - which means they've written it poorly. It is not clear enough whether we should be multiplying by 3 or its reciprocal.
Now, if your programming language of choice happens to understand what you've written correctly, then so be it (which was what I meant by my post, I wasn't making fun of computer scientists :p), but from a mathematician's point of view, the problem is poorly written, and if you wrote that down on a piece of paper I'd ask you to write it again.
I thought comp sci guys had to have a decent A level in maths to do a degree. So we all agree that this 'problem' would only present itself as a result of user error?
You are right - the notation is rubbish, but apply the universally accepted standard order of notations and you get the same, right answer - 9.
terms inside parenthesis
exponents and roots
multiplication and division
addition and subtraction
Parsed left to right.
