Will Z68 motherboards support 16x PCI lanes with SLI/crossfire ??
Only if they have the NVidia NF200 chipset like in the P67A-UD7.
The Sandy Bridge CPU's physically don't have enough PCI-E lanes for 16x/16x, the Nvidia chipset splits the 16 lanes it does have into 32 (or some other form of witchcraft).
As far as I'm aware the main advantage of Z68 will be overclocking whilst using the onboard GPU.
It also uses the onboard GPU for video acceleration and also SSD caching.
the Z68 boards will have PCIe V3 lanes, which are twice as fast as the PCIe V2 on the P67 boards i believe. so x8/x8 on Z68 boards will be the equivalent of x16/x16 on the P67 boards
I thought PCIe 3.0 was coming in the generation after z68? With ivy bridge?
To quote the answer i got when i asked the same questions
The Z68 seems fitting someone who wishes to overclock and use igpu
P67 who wishes to overclock and use graphics cards
H67 for those wishes to use neither overclocking or graphics cards and just run decent low cost machine.
even if the z68 had pcie3.0 slots its wouldnt make a difference if the CPU doesnt support it, and untill ivybridge, it wont.
