If you want to keep an i5 at stock, I don't really see the point in buying the K edition. At least, that was my thinking.
At the moment a 2500K is actually cheaper than a 2500 on OcUK so you might as well get a 2500K whether or not you plan to overclock.
If anyone is wondering, the motherboard was found faulty, so my spidey sense was correct.
That's balanced out by the idiocy of trying to install my old 1.65v RAM into the new mobo, which supports 1.5v RAM. Didn't realise until I had a mess around inside the case and saw it written on every DIMM slot.
D'oh.
Glad you got to the bottom of it, however the 1.5v is just guidance, most modules are 1.65v and work fine with SB. Infact many of the SB "tuned" memory is 1.65v. There is zero evidence that running 1.65v is going to do anything bad to the system.
I had to reinstall windows because it insta-BSOD'd every time Windows started up.
Could have been AHCI settings, if windows was installed with it turned on and the new motherboard was set to off, but hey, a fresh install never does any harmThat's great about the boot times too
I've never overclocked, but I want to give it a try - but these horror stories put me off, as I only work part time (money shortage!) and couldn't live without my computer for any length of time (yes, I'm the kind of saddo you see on holiday paying 50p for 15 minutes computer usage in hotels)
