Laptop memory?
30 Dec 2009
Wigan Lancs
As long as you have a slot available, you should be able to put some SODIMM memory in but it will has to be the same as the memory already in there if you are not taking any out otherwise the memory you have will only run as fast as the slowest in the laptop.
Hope this helps
Hope this helps
So if i replaced all the memory is there anything faster than 800mhz that will fit.
Dual cannnel type too??
You may need to look into it a bit more to see what your laptop can and cant take but there is something like this:
Link
Does your laptop take DDR2 or DDR3 memory?
what you previously linked should be fine then, might be an idea to see what others think
aswell to make sure you get the best memory possible :)
