Does a GTX 275 run cooler then a 8800GTX ??
Caporegime
27 Nov 2005
Guernsey
Does anyone know if a GTX 275 runs cooler then a 8800GTX ???
As am using a 7800GTX 512mb in my shuttle computer, but i have a spare GTX 275 laying around doing nothing and i was thinking of using it to replace the 7800gtx in my shuttle.
But i that a 8800gtx temps get to high when fitted in my shuttle so i was wondering if a GTX 275 would run cooler..
Not sure about this but I had a 8800gts 640mb and I think it has cooler than my gtx275.
The good news is that the both 8800 and 275gtx have blower like fans so heat will stay out of your case/shuttle. Are you sure the gtx275 will fit your shuttle though?
This is my shuttle with my 8800gtx in it.(And i think the GTX 275 is the same size)
I used to run 2 x gtx 275's in sli, found them to be pretty hot running cards, even more so than my current sli'd 470's, the 275's were always ran at stock, due to the heat they produced, the 470's run a lot cooler and i can overclock them without any issues.
I used to run 2 x gtx 275's in sli, found them to be pretty hot running cards, .
I also used to ran SLI GTX 275 (BFG OC)...Replaced them with SLI GTX 580
Now have one my GTX 275 in my HTPC and the other one just sitting in the loft..
Am Thinking of flashing the bios with a clock speed of 500mhz so it run cooler..
