- 10 Mar 2006
ny of you guys handy with wiring? I'm trying to replace the kitchen splotlights with one of those compact round fluroescent tubes for more light, but after fitting it to the ceiling I can't work out why it's not working.
The previous light has two mains cables to it, with the spotlights (as one) being wired with a shared earth, and both the live/neutral cables running to the same place.
I've tried doing the same with the new spotlight, using both lives, both neutrals and the ground they've combined, which works, but when it turns off the fuse trips. Also the switch is now the other way around, which I can't work out why. I've also tried just ignoring one of the cables and wiring it up, still using the same shared earth, but it doesn't work at all then.
Any ideas what I'm doing wrong? I'm being careful with it all by the way, turning the fuse off whilst fiddling. Thanks.
Uploaded with ImageShack.us
