i7-950 4ghz low voltages but high idle tempreatures?
18 Jun 2010
Hi, so i've had my i7 for a few days now and have it running stable at 4ghz with a Scythe Mugen 2 heatsink/Antec 300 case.
My problem is the idle temperatures really bother me, considering my voltages are quite low.
Idle temp 44c, 62c full load prime95 (70-74c with HT on)
Vcore (in CPU-z): 1.16v
QPI/Uncore: 1.24v
CPU PLL: 1.86v
IOH/ICH: 1.16/1.20v
DRAM: 1.65v
HT disabled, 21x 191 BCLK
To me that's kind of high for idle on those voltages, I read people getting 32-38c idle with higher voltages (from 1.25v to 1.3v) at same clock speed? :confused:
I've just reseated my Scythe heatsink for the 2nd time (pain in the ass) using Arctic Silver 5 - this time using the small center blob method, but alas no difference to when it was first seated (single line method - was a little too thick though).
It may seem like i'm a little anal about it, but I use my pc a lot and having around 10c+ extra compared to the standard of everyone else does bother me.
Any advice on how I can solve this? thanks for reading.
Case temp is 26-30c, 3 intake (2 front 1 side) and 2 exhaust (3 if you count PSU).
Graphics card idles on about 27-31c (GTX 460) so I don't think my case is that hot?
I have idle of about 39c on the stock cooler and vcore shows as 0.93
Idle of 55 when vcore is 1.31 and 4ghz on stock cooler. Full load for 366secs = 97c :eek:
I think its just about still within spec and the stock hsf is really this basic. It has grand total of zero heatpipes as far as I can tell.
Basically this is the same heatsink design as I used on my old AMD Athlon except I had a zalman 100% copper
Apparently Bloomfield is certified to 100c where as Conroe was to 85c only
