The problem with BODMAS is that division and multiplication are equal, as are addition and subtraction. As posted many many times already it's a simplification you learn at school to help get your head round formulae.
Degree and, as of today (literally!) thanks to Cambridge changing their name for their 4th year, Masters in mathematics and a PhD in string theory. I'm, by job title, a 'mathematics researcher' too.
That is pretty intimidating. I was a bit of a chancer when I did my humble BSc, you are obviously extremely dedicated to maths. I wish I had the time to spend on learning more (and refresh my memory on things like PDEs). I was considering doing a masters through OU but I ended up spending time on learning IT stuff like Citrix instead :/
Yes but there are still arbitrary standards that we follow
2x^2 being 2(x^2) and not (2x)^2
a/bc is technically (a/b)c or ac/b and not a/(bc)
this is a known source of confusion when using the / or ÷ operators and the reason why this question has caused so much fuss - there is however a standard way to use those operators regardless of the silliness of the question
a/bc is not technically (a/b)c as it is commonly understood to mean a/(bc) and the reason it is commonly understood to be that is due to the question being phrased ambiguously.
That would be me. That document I wrote before Wikipedia existed and which I used to learn LaTeX. Now I have to stop myself from typing LaTeX into forums when I want to talk maths \frac{like}{this}So you are AlphaNumeric right? I think I still have the PDF you made of the 0.9r proofs.![]()
My job is now working on various areas of mathematics which I otherwise wouldn't have ever done if I'd stayed in academia so I'm fortunate in that sense. I'd still be focusing on the tiny tiny area my thesis pertained to, while now I've had to learn a wider range of things, from more in-depth functional analysis through to optimisation. That and I'm actually doing useful maths now, there's not a chance in hell my PhD will ever be experimentally tested.I wish I had the time to spend on learning more (and refresh my memory on things like PDEs).
Sorry but this is the same argument as this very thread and we do have a convention for '/' it isn't ambiguous if you stick with convention. It does have potential to confuse so parenthesis should be used for the sake of clarity though there is still only one meaning technically.
The practical effect is that you should never write an expression like a/bc unless you are sure it won't generate any confusion -- e.g. if you can be certain your audience will infer from context whether you mean (a/b)c or a/(bc). That is what the question is doing and you cannot infer what it is implying.
Problem is, without knowing the expression writers intentions, you might get the "right" answer to the wrong question.Totally agree and you should never write an expression as per the OP - it doesn't prevent us from using standard convention rigidly to answer it.
This is why mathematicians use better notation. I mentioned in my last post I have to stop myself typing LaTeX code when I want to put maths here. If I wanted to say (ab)/c) then I'd type \frac{ab}{c}. If I wanted to do a/(bc) I'd do \frac{a}{bc}. That makes the expression unambigious. It's considered extremely bad practice to type a maths paper (or even lecture notes really) in LaTeX and use / as a divisor. By using this proper pseudo-code in LaTeX you remove any ambiguities. I often write emails in LaTeX code, when communicating with other mathematicians, as you get to the point where you can 'compile' it in your head and thus the structure of the code helps you avoid such ambiguities.a/bc is not technically (a/b)c as it is commonly understood to mean a/(bc) and the reason it is commonly understood to be that is due to the question being phrased ambiguously. Please read up on ambiguity.
