What about the thousands of DIY forums out there, should they be banned too?
If they are giving advice on electrical work or gas work then imo yes
If you don't work in the trade you won't agree, So trying get my point across with you is pointless and a waste of my time.
You can do just as much if not more damage messing about with electrics as you can advising someone what pain killers are best.
Was on here the other day and people (yes more than one!) were advising someone to bypass the main RCD in a property that wasn't even the guys own!
If he had actually attempted it (people do these things!) First the incoming supply would have been live (They failed to mention this) and secondly if by some freak act of god he didn't blow himself up or pop the main fuse, He would have left a property (likely to be TT) without any RCD protection and then invite 20 of his friends over to sample it!
It's not right tbh.
This thread is for a very simple light fitting, Yet the first bit of advice is
You need a spare connector block - put the 2 blacks into this then use the 2 reds in the light fitting - one in the live and the other in the neutural.
See it nearly every electrical thread.
