6950 OC Twin FrozR III unlockable or not
But only 1 BIOS I think? So not as "safe" as unlocking the reference 6950s
It has the switch:
and
Tpu said it can be done:
'Like on the AMD HD 69xx reference designs, a BIOS switch is present which lets you select between the original BIOS and a backup BIOS in case something goes wrong with a BIOS flash. Combined with the HD 6950 to HD 6970 modding potential this makes an unbeatable combo because it's almost impossible that you screw up enough to end up with a $300 paperweight.'
http://www.techpowerup.com/reviews/MSI/HD_6950_Twin_Frozr_III/4.html
Have a read of the comments section:
http://www.techpowerup.com/forums/showthread.php?t=142870
It's not clear whether a BIOS flash will work or if you have to rely on RBE. Post 13 implies that the switch (which is meant to switch between "Performance" and "Silent" fan profiles) actually switches between BIOS. But he failed to flash the card. I'd like to see concrete proof that someone has successfully modded the card. I find it strange that even Wizzard didn't test to see.
Cheers for the feed back, I was a bit confused cause I looked on overclockers page and nothing was mentioned about it being rev 1 or not. weird
nice find mate
not sure wether this is useful or not but the switch on the 6970 version is for 2 different profiles for the fans 1 for quiet mode and 1 for performance mode.
i really don't think the 6950 version would be unlockable
Apparently there are two versions of the TFIII, and it's only the first batch that can unlock. Stick to the Direct CU II 6950 if you want an unlockable card.
