Lancool K62
6 Jul 2008
Brighton
Hi guys considering this case for a build but cant seem to find much about it. Anyone got any opinions or build pictures please.
Yeah ive seen a few reviews but would like peoples experience with it, e.g whats it like for cable management, noise and dust.
Cable management is a breeze, dust filters aren't great but they do stop most dust and the stock fans aren't that noisy at all (although I have them on a fan controller now).
I love the case. The tooless design is great and easy to use. Everything seems to just work. However, the only bad points I have found is although watercooling is possible with it, you can only fit a 280mm slim rad in the top (without modding) which I have found is too small for a GPU and CPU loop.
Here is a link to my build log: http://forums.overclockers.co.uk/showthread.php?t=18220824
When it was air cooled
And on water
And here is a video of mine when it was on air
Hope this helps :)
i had the K62 case as well really good case, the case air flow was gr8. cable mangement was really easy on this case and i had my watercool set up in this as well, here the link.
8/10 from me for this case
I have the K58 which is the same thing except it's silver inside, lacks the side window and doesn't have LEDs in the fans. Lovely case, brilliant to work with and oodles of space. Personally mine is noisy but that is because I'm not terribly bothered about noise and have my fans at 100% (Although I should mention these are my CPU and graphics card fans that I'm talking about, the ones in the case seemed quiet enough)
