Best motherboard for under £40
29 Apr 2011
I am very skint post-university. But, one of my dimm slots on my motherboard has broken and I'm only running on 1gb DDR2 when I have a total of 3x 1GB DDR2 sticks ready to use.
Bearing in mind I only have DDR2 ram, would it be worth getting a cheap combo ddr2/ddr3 board? Or just get a cheap DDR2 board and wait untill I do a full upgrade in 6/7 months?
All the best,
Ben
All the best,
Ben
What CPU is it for?
Sorry, school boy error there.
AMD 64 x2 4600+
Crucial ballistix 1gb ddr2 ram
Picking up HD 46/48xx in next week or two. Need a new PSU (undecided on a cheap one) apart from the GFX and PSU (and mobo ofc) rest will be reused.
Cpu-Z
Name: AMD Athlon 64 X2 4600+
Code Name: Windsor
Package: Socket AM2 (940)
Technology: 90 NM Core Voltage 1.2xx V to 1.3xx V
Family: F Model: B Stepping: 2 Ext. Family: F Ext. Model: 4B
Revision: BH-F2
Instructions: MMX (+), 3DNow!(+) SSE (1, 2, 3), x84-64 , AMD-V
Bad news.
If you're stuck at less than £40 you only have a choice of 3 and they all only have 2 slots for DDR2 memory.
This one only has a PCI-E 1.0 x16 slot:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-149-MS&groupid=701&catid=1903&subcat=1483
This one has a PCI-E x16 slot but doesn't say what version:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-028-AK&groupid=701&catid=1903&subcat=1483
This one has a PCI-E 2.0 x16 slot:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-241-GI&groupid=701&catid=1903&subcat=1483
I'd go with the last one or stretch a bit for this:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-269-GI&groupid=701&catid=1903&subcat=1904
I, too, need a new mobo - my IP35Pro is on its last legs. I have a QCore 9550 and 4x DDR2, whats a decent LGA775 motherboard nowadays? I have about the same budget as the OP, give or take a tenner.
You're struggling a bit there.
There are a few DDR2 microATX motherboards at OcUK still available for S775 at around the £40 mark but they only have 2 RAM slots.
I can't even see anything in the clearance section.
You're probably going to have to look at second hand.
Well, if he didn't buy it then, he certainly can't now! ;)
Captain Obvious strikes again!
