I'm genuinely undecided. I think that AV is an ever so slightly better system than first past the post, but it's so similar, and will produce such similar results (yes, it will) to past the post, that I just don't think that the change is worth it.
In an election with more than two candidates, AV maximises the number of happy voters where FPTP mathematically can't.
Also in Australia, AV has created what is effectively a two party democracy and that's not something I would like to see.
In all honesty though, do you think your political masters will interpret it, or at least present it, that way?Voting No to AV doesn't mean Yes to FPTP...
How has AV managed to do this? If a party is weak enough to have their candidates eliminated under AV then surely they will be eliminated under FPTP too?AV in Australia has forced the weaker parties to form a permanent coalition in order to compete, that is not something I would like to see here.
The Fijians have an issue with apparentment, not something that is being considered in the UK. And as for Australia looking at returning to FPTP, that's just wrong, I challenge you to find any of the main Aussie political parties supporting a move to FPTP.Castiel said:In fact in Fiji there are moves to return to a FPTP system and in Australia the reform lobby are also campaigning to return to a FPTP system.
Well if you will base your opinions on falsities....You might find this analysis of the recent Aussie poll that the No campaign keep talking about interesting: http://blogs.abc.net.au/antonygreen...n-surveys-of-the-preferred-voting-system.htmlCastiel said:Neither seems to be indicative of the "stepping stone to PR" that you seem to think is automatic, quite the opposite in fact.
It hasn't "created" anything more than FPTP has created the political system we have here. Australia also happens to have a fully elected upper house voted in under a full PR system that has similar powers to block legislation as the House of Lords, you do the country a disservice by only looking at its lower house.Castiel said:Also in Australia, AV has created what is effectively a two party democracy and that's not something I would like to see.
Voting No to AV will be treated, politically, as Yes to FPTP. As is evident from the current campaign all the Conservatives and half of Labour have no desire to change from what we have no because it gives them power (cyclically) and they don't want to share, they'd both rather be out of government for several terms in a row than be permanently reduced to their appropriate size.Castiel said:Voting No to AV doesn't mean Yes to FPTP, it simply means AV is not what people want, it doesn't impact on the need for electoral reform, in fact a No vote will not silence reformers and will more than likely increase their numbers as this referendum has increased awareness to the issues our electoral system has.
I refer you again to the Canadian situation, high targets were set for changing the voting system in some areas (60% approval required to pass) it was missed by 3% and a couple of years on there is no longer a body of people supporting reform, change breeds change.Castiel said:Whichever way you vote, Parliament will see that as a vindication of that system, only with the No vote we have had no change and so the same argument from the reformers remain and probably increased by more awareness of the issues with FPTP and in all likelihood we will see MPs backing more substantial reforms to the Constituency and Parliamentary systems and in turn revisiting the voting system. Voting Yes to AV simply vindicates AV as the change reformers are calling for, thus undermining their own campaign for PR.
It sounds like something else other than AV was the root cause i.e. unpopular politics.
Especially given they're not 'our' political masters in the first place.I'm not sure your opinion on our political masters will be the most tempered![]()
AV.
Anything the Conservatives and BNP don't like MUST be good.
Or a split vote.
Whatever the reason, AV in Australia has arguably failed, so much so that recent polls suggest a return to FPTP is what the electorate want, in Fiji that is what is happening, I suspect that Australia will not be far behind.
AV is not a better system than FPTP, it simply has different problems.
You can have all the reformers and campaigners you like, but if you don't have anyone with the power to change things supporting your position you're not going to get anywhere.
A return to FPTP in Australia? There aren't going to be many people left who have ever voted under it being as preferential voting came in in 1918. Your suppositions are unsupported flights of fancy that just show how unfamiliar you are with politics in other countries.
Show me that the ALP want to move to FPTP.The main Australian Party.....the opposition are a coalition of smaller parties.
Since when has what the Parties supported been the same as what the People want.
Here the people want PR, yet the Lib Dems are supporting AV.....
The context of what was happening at the time of this most recent, and the other surveys is important, which is why I bring them up, although I can see why it'd suit you to write them off as irrelevant.Castiel said:The result clearly shows a preference for FPTP over preferential voting. Going back 30 and 40 years is hardly indicative of the feeling of the current electorate....
Frankly your pontifications mean just as much.Castiel said:Nice soundbite, but ultimately it doesn't mean anything. If AV wins, AV will be the new permanent voting system for at least our lifetime if not longer.
I haven't heard any problems with AV that FPTP doesn't already have, beyond FUD - which isn't a legitimate reason to stay with FPTP.Vote AV you will get AV, it will not be a shortlived stepping stone to PR, it will simply be a more expensive system that gives practically the same results with different problems.
