This isn't going to be the most constructive review ever, but I really don't have much good to say about it.
I've driven it all of 10 miles, the seats offer no support, the lower area of my back aches. And yes the seat is adjusted properly.
The steering is so light there's next to no feedback, the steering wheel is too large and the rack isn't fast enough.
The gearbox has no feeling, you push it into what feels like a gear and release the clutch in hope more than anything, everything feels just so light, the driving experience is none existent, like you're a passenger rather than the driver. I can see if this is all I had to drive I would go off driving rapidly.
It's not all doom and gloom however, the cabin is very light and airy and there are extra windows behind the wing mirrors in order to aid visibility. All round visibility isn't too bad either. Dashboard isn't bad, functional but nothing special. On the 10 mile journey from the garage I managed 49.5mpg without really trying, there's hardly any in-gear engine braking which helps you coast quite well.
You can tell car manufacturers have gone all eco-centric from the instruments, on the rev counter there's 2 lights, one to tell you when to change up and one to change down, there's also an eco light which illuminates when you're driving economically. Great.
It's also a very quiet car, the engine doesn't really make much noise and will rev to 7000rpm ish, I didn't get a good sensation of speed though and so entered corners a bit quick and it felt a bit roly poly, but a car more geared towards comfort and ease of use, that's not surprising.
So I really don't have much good to say about it, and my review may be a bit crap but there we go!
