duel monitors
18 Oct 2009
I need to get a new gpu for a friend that can output to a 1080p tv for films and do vga for the small monitor that they also use at times. It will need to be able to output to both at the same time as well.
Lastly, as cheap as possible.
Thanks.
Loads of GPUs can output VGA and HDMI. OCUK won't have them but plenty of other sites with a larger range of products will have.
If you don't know where to start try looking at a GT210. I'm sure you can find cheaper though.
EDIT: just make sure they can play 1080p content.
Duelling monitors.... whatever next
LOL!
The 5450 will be fine. Just make sure you configure the player properly to use GPU acceleration for 1080p films.
