Permabanned
- 28 Mar 2011
- Space Man INIT
This has been around for sometime and has made lots of noise within the audio side of things. I though i would give it a crack.
The main hype is the 32bit DAC and the transporter being the best there is.
eBay and £4 latter i got my self a SCPH 10002 delivered (02 is the UK version).
It cam with the RF, power cable and the controler.
There is some very good forum topis about, i've been using the one over on DIYAudio.
One guy has a website from Germany with all the mods which i will be perfoming
http://dogbreath.de/PS1/index.html
I've had a quick listen and already it's better than my Arcam Alpha 9 with it's own 24 bit ring dac or if use the digital coax on my dac magic.
The mods should really open it up more and as it burns in with the modded parts sound even better.
