Need 1000w PSU recommendations.
Yeah, they're meant to start making straining noises as well when you start pushing them. That's extra noise you could do without as well!
Meaning you want a PSU that exceeds by a fair margin the combined power-usage of all the parts?
As in, while a 850w might be enough, if it's only just enough, it'll be running full-whack, which isn't good, right?
Yep, think of it as a car engine.
You also dont want to run a PSU maxed out.
+1 > 1000w, especially if your going to overclock your CPU + GPU'S as well, they say you should not take a PSU over 70% of its power, as you are starting to stress the unit which can effect stability in overclocking, etc, as well as reliability, the PSU is the No1 component in your build.
My vote goes for the Corsair AX 1200W. Here is a review.
It may be £225, but for that money you get an excellent performing, fully modular and highly efficient PSU. Also, it comes with a seven year warranty - which gives you some peace of mind.
Silverstone ST1000P easily. Good reviews and for £150 it's a steal. 100% modular and 80plus silver. It's small and silent
Just getting back to this thread, thanks for all the replies, I'm looking through them. I'm at a point where I'm reconsidering the 580, but as a reference I have another question that should help me no matter my decision.
So I've learned that you need to have a PSU that exceeds the total wattage needed to power a whole rig effeciently (keeping the strain below 70%), but is there a point that's too low? like if you buy a PSU that has way more power than you'd ever need, and you were only running like 40% (an example), does it lack efficiency then too (as in waste energy), or not work correctly?
Thanks for all the replies!
Yes, its best to run a high frequency switching mode PSU at around 50-60% for best efficiency.
take this bell curve for the TX750
