Best bang for buck upgrade from GTX260216?
Caporegime
3 Jan 2006
Chadderton, Oldham
As above, looking for a good upgrade from GTX260 216, was a bad buy really this card should have stuck with HD4870, but I'm not wanting to spend much, £100 MAX.
Thanks.
For £100 you're not going to get much of a speed bump. Would suggest you stick with your current card for a while unless you're happy to buy something 2nd hand
I would also keep current card and save up and till you can get something worth buying, not much of a performance boost for the money.
Thanks.
You can have deals on HD5870, someone sold in MM for £100 delivered!
I would personally save up a bit more.. or if you can, save up a bit sell your current gfx card and put the funds towards a GTX 560 TI, or if your case can contain them a 6950.. both of which would be a significant upgrade to your 260.
