New build - Advice
17 Jun 2004
I don't tend to upgrade as often as I should but thinking of the below spec to keep me happy for a couple of years. Is there anything else I should think about or change to get the best bang for my buck?
I will be watercooling everything so I went for the 6970 over the 6950 due to the better ram. I will get a 320 and 240 radiator for this case which should keep everything cool. My only concern is the PSU but heard its good for 900W. For reference I game on a 1920x1200 screen, I know the gpus are overkill now but as mentioned won't upgrade PC for 2 years.
2 x HIS ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card with FREE Games Pack
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive
Corsair Obsidian 700D Full Tower Case
Intel Core i5-2500K 3.30GHz with FREE Operation Flashpoint Red River Game
Asus P8P67 PRO Intel P67 ** B3 REVISION **
Microsoft Windows 7 Home Premium - Retail
Corsair HX 750W ATX Modular SLI Compliant Power Supply
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Samsung SH-B123L/RSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive - Retail Black
Total : £1,644.67
Yep, hence my point about the better ram on the 6970, from what I have seen the 6970s getter better clocks than the 6950s when using water ;)
Thats fair. The games make the card a better deal as well. I don't know that muh about water cooling, lol.
Everything else looks good. The power supply should be able to run everything, but I don't think by much. Corsair are usually a good make.
My friend is going to buy my current rig so to sweeten the deal was going to give him the 2nd game pack if I decide to x-fire 6970s. As it adds quite a lot to the cost especially having to get two waterblocks as well.
I have a corsair PSU now and would definitely use them again, just not sure whether to get the next one up in terms of power.
1x GTX580 would run everything perfectly fine for 2 years at 1920x1200 without issues of having to get correct drivers, or irritating micro-stutter than tends to afflict two or more cards running in parallel :p
PSU will just about cope, depending on clocks on cpu and gfx.
I would consider 800w/850w ideally if you want to overclock.
