Next easiest step for data throughput for home users is SSDs plugged straight into a PCIE socket - actually, I think OCZ already did it... anyway, point is, that can be done already.
SATA 4?![]()
SATA 4?
I wonder about the PCI solution though. OCZ's RevoDrives already do it: http://www.overclockers.co.uk/search_results.php?sortby=&groupid=&search=revodrive
Don't think they ever really took off though?
Not fast enough. Only 540Mb/s read (slower than SATA3's theoretical, not sure about actual) and VERY expensive. I'm sure PCIE can do a lot faster than that, especially on more lanes (that looks like a 4x ?).
Heh, I was surprised no one had posted it already.I was planning to answer with this before I saw your post.. DAM YOU![]()
When you reach the point of needing more throughput than the theoretical maximum of 774MB/s of SATA3, you're not just an enthusiast, you're clearly doing something critically data intensive, at which point you'd be using a proper storage solution using hardware RAID SAS, or even fibre-channel DAS.
That may be so today but SSD technology is moving very quickly. I wouldn't be suprised if most mainstream SSDs were reaching this speed by the end of 2011 or early 2012.
