Just about to order the parts for my first full build so would you guys mind giving the basket a quick look over to check things are compatible and the such? (I suppose i'm a little paranoid of things not working
What kind of speed should I expect to OC the CPU to on the stock cooler? Or is it worth throwing a bit more money in for an aftermarket and going higher?
Also is it really worth flashing the 6950 to a 6970? A friend of mine couldn't get it to work but from reading around it seems that not many people have had problems with it so I might give it a go.
Thanks
Thanks
